General Head Lamp Protectors
FM02MZO
Castle Donington
I have a 2013 Fiat X250 based motorhome, and I am thinking of buy a pair of headlamp protectors with the beam deflectors for use abroad.
Can they easily be removed when back in the UK and do the fittings mark the body, or do you have to leave the fittings in place?
I have a motorhome and i fitted the headlamp protectors in actual fact i have had two motorhomes and i have fitted them to both
1) they protect the head light
2) they are marked with where to fit the beam deflectors (sopplied)
3) as the head lights are plastic i was told that some stick on deflector may mark the headlight which may cause a M O T fail.
I don't remove mine most of the time but when i took my fist MH for first MOT it had been fitted with lefthand drive headlights so Two new headlights had to be fitted the protectors had not marked the lights or the body. Hope this helps.
