Technical Hazard signals works without reason
goride
Israel
In my 2013 panda, my hazard signals lights work without any reason. Switch is turned off and key outside, the lights go on. If I turn them off, they might stay off, or turned on again randomly.
BCM? moisture? Faulty earth link?
Any ideas?
Isn’t this a repeat of an earlier post?
Thanks. I'm not sure I understood which bulbs did you replace.
Hi my problem was when I was driving along the hazzard lights would come on and if you had to use the hazards they would switch on but then wouldn’t go off so I replaced the set of switches which included the hazzard switch
