Technical  Having issuse
Puzzled to say the least.coming home from a walk with the family and notice that front didn't feel connected to the back.next day tried jacking car up to have a look at the front but the wheel stayed on the floor,i checked the other side front and that did the same.dropt the car back down and tried again.jacked the car back up at the same jacking point and the wheels lifted on both sides.I checked everything and everything seams fine.went out for a little spin and while accelerating the car pulled to the right like torque steer and the back felt loose again.so as I said puzzled. Any ideas would be a massive help.I'm thinking shocks but not sure...
Many thanks
You looked at the top mounts ? Make sure they are tight also have you changed any springs or anything recently? You should take the front wheels off and check all the bolts/connections make sure everything is in good working order, have you hit any big pot holes recently ? Because that could have shot the alignment out.
