Have I got the wrong part??!
Dom
Please see below, a little worried I may have ordered the wrong part?!
> Back to Main
Where can i buy a potentiometer for a 1.2 Brava?
April 16 2007 at 10:57 AM Dom (no login)
from IP address 81.109.57.156
As above. RAC told me the potentiometer had failed.
Thanks in advance.
Respond to this message
Author Reply
Anonymous
(no login)
90.196.80.205 Re: Where can i buy a potentiometer for a 1.2 Brava? April 16 2007, 1:27 PM
Is this the headlight alignment switch? Can get one from a scrapper. Unless it is off the ra
Anonymous
(no login)
81.109.57.156 Re: Where can i buy a potentiometer for a 1.2 Brava? April 16 2007, 3:01 PM
No its to do with the accelerator.
AlexW
(no login)
89.240.169.104 Re: Where can i buy a potentiometer for a 1.2 Brava? April 16 2007, 8:47 PM
According to Haynes, the throttle potentiometer is integral with the idle actuator. So it may be an idle actuator you are looking for.
Also according to Haynes,on later models the potentiometer is integral with the throttle body.
So first, you will need to find out which yours is. If it is part of the throttle body. it may be like the 1.4 and you will need to renew the complete throttle body.
Hope this helps.
Anonymous
(no login)
81.109.57.156 Re: Where can i buy a potentiometer for a 1.2 Brava? April 16 2007, 9:38 PM
fiat have the part but its very expensive i was wondering where else i can get one. Also they sell it seperately.
axle
(no login)
90.201.162.223 Re: Where can i buy a potentiometer for a 1.2 Brava? April 16 2007, 11:13 PM
Everyhing you buy from fiat is expensive, Try the scrappers. These are usually reliable components so you should get a good one from a scrapyard
Rusty
(no login)
134.151.33.100 Re: Where can i buy a potentiometer for a 1.2 Brava? April 17 2007, 9:27 AM
If I were you, I would change the whole throttle body + idle control valve with a scrapyard one. The throttle position sensor is integrated into the ICV, but you could have a fault with the TB itself. If you swap the lot, you know you've got a working unit. I got one for my 1999 1.2 brava a couple of weeks ago. £45 from Fiat Base in Birmingham (0121 3335296). I can definitely recommend them if you are anywhere near. They have a mountain of bravo/as in all the time and they certainly know what they are talking about.
Just be aware that there is a possibility that you will need to get it on the Fiat examiner to rezero and relearn the idle adjustment if you disturb any of these components. I had no problem, but the manual says differently.
Anonymous
(Login tj2002)
87.81.28.64 Re: Where can i buy a potentiometer for a 1.2 Brava? April 17 2007, 3:47 PM
Cheers for posting this up for me Adam and for all your help through this difficult time! It's gonna be with a garage in Bristol, I've borrowed a 1.4 gsi Metro for the week! I've ordered the parth from parts gateway and the guy on the phone said they had one that was to do with a throttle cable and one that was 'fly by wire'.
Please say I went for the right one!!! It's being delivered down to my grans 2morrow morning and being fitted over the next day or so. I'm a bit worried it's not gonna be the right fix now, the RAC diagnostic definately said throttle positioning sensor (potentiometer).
Re-assurance anyone??!
Anonymous
(no login)
194.75.37.250 Re: Where can i buy a potentiometer for a 1.2 Brava? April 18 2007, 12:23 PM
Rusty, Alex W, do you reckon I've ordered the right part, I'm in Manchester now ans the car's in Bristol, a tad worried now!!
