Technical  Half shaft dimesions
YO11
Hi guys, just popping from panda classic section.
As i'm lifting my panda 4x4 i'm considering using longer drive shafts. This will be accompanied with lower arm, ball joint and tie rod modification.
If someone have a spare pair, would that be possible to measure the total length of the bare shaft, short and long.
It would make sense that Uno shafts are bit longer as the whole body is but i'm strugling to find any dimms as most are for full drive shafts.
Im looking for 10-15mm increase, so not dramatic difference.
I've found that the short (n/s) is 434mm long , can someone confirm?
As far as I know the spindle is same 19 teeths at the gearbox side/tripod and 20 at the outer cv.
Jacob
ps. can uno mod ammend that spelling error in the subject. Cheers
