The main problem i found with gt's after buying 9 is that some people whap the boost up and dont realise the damage,pistons melt,turbo seals and h/g failure all due to not realising the "danger zone" of an engine,remember theses are up to 17 years old. the engines are good if theyve been looked after,but with age you have to contend with rust,bushes gearbox trouble,like sei says try and get the car as cheap as possible a cam shaft fitted correctly at a garage would be around the £500 mark.The less you initially outlay on a gt the more you can mod it!
