General Grundig AD 182H !
Radio
bitola
Hello all !
I bought a secondhand radio Grundig AD 182H, and in my model I have a Fiat Brava Grundig AD 182L that is not working?
How do I dismantle an older model because I want to replace it with new?!:confused:
Is there a manual that button which is used to model 182H!:(
Is Grundig AD 182H has a code, if there is how to find out!
thanks
Grundig AD 182H - Problem?!
Hello all!
Give the people that help to repair?
When i press the eject (open) button on the radio Grundig AD 182H (see picture dawn), the cover can not be raised in order to remove the cassette?:confused::(
I'd say what's the problem? :worship::idea:
Its a very common problem, press the button and lift it from the top to open it.
You can get repair kits with springs and a spring bar to repair it.
Somehow, i solved the problem, since they were disconected springs?!
Now i have another problem: When you turn on the radio to play for about 20 minutes for automatic disconnection!:mad:
Give please tell what's the problem? And how to solve it?:confused:
thanks
thanks
The radio goes of after 20min if the car's engine is not running, to prevent the battery going flat.
Hello Adrian!
I let the radio play and 20-minute radio disconnection if moror still working?
again press the "on" worck to extend it for another 20 minutes!
Cheers
It sounds like it has lost its permanent live feed.
It should have an ignition live and a permanent battery feed.
Friends !:)
I have solved the problem .. was interrupted nerves ignation with connectors labeled 4 (see Figure1 connectors).
Cheers
