Grinding....
Grinding....
J
James
fitted my new 17" fiat stilo wheels a few weeks back, but on full lock they grind! i was under the impression that 17's fitted with no trouble!
any help most appreciated.
james
Re: Re: Grinding....
205/40/17 - (i think) they are the ones fiat recommended) they are low profile yokohama A539.
Re: Re: Re: Grinding....
what width are the wheels themselves?
if they are more than 7" then that'd be why they are rubbing.
which stilo wheels are they by the way? look nice? got a pic of them, or of them on your car?
Re: Re: Re: Re: Re: Grinding....
To get the pic in the forum you need to select it then click on get link to this picture then copy and paste that into here, All the one you have put sends ppl to the fotango login screen
SY B
Are you sure
Are you sure they are rubbing and its not just the power steering sqeeling at you. Mine started to do that as soon as i fitted my 17's!
Kev
Re: Are you sure
definalty grinding on full lock!
i can feel it as well as hearing!
james
Re: Re: Are you sure
The Pic...(i hope)
Cheers for the help SY B
Re: Re: Re: Are you sure
No Probs, remove one of the front wheels and have a look what it is grinding on this should give you more help
Re: Re: Re: Re: Are you sure
Cheers Sy, ill have a look when i get back from work at the weekend!
what do you think it coul be? could they be set too far in?
Re: Re: Re: Re: Re: Are you sure
No idea james i'm the wrong person i don't havce alloys yet so haven't experience the problem,
Once the whell is off thought i would look for rubbing marks around the arch etc and check the tyre, see if it is being worn away, If it is grinding though could the Coer behind the disc not have been damaged or bent?
Could be the offset
Could be the offset if they are rubbing outside edge!
Im guessing it will be rubbing on the front edge of the tyre centrally though - just on the edge of the bumper (or do you have the mud-gaurds cuz they will rub).
if you take a hump back bridge to quick while turning it will rip your arche out! Lol
Kev
S
2
342
Anonymous
A
K
12
356
Anonymous
A
P
1
163
Tommy K
T
K
7
407
K
