Well not exactly sure.
Got oil changed and there was a leak after. Was checkin oil and toppin up as needed. Didn't get a chance to go back to oil change place, was on 401 driving 110kph low oil light flickered . Lifted foot off gas and car shut itself off.
Pulled over and there is/was oil everywhere. Had it towed home and can't c where it is leaking. Am not aloud to work on cars place i live so filled oil back up tried starting car and sounded like no fuel. Put can of gas in to make sure there was lots. Was cranking the engine and it made a clunk and now nada.
Got old convertible back on rd and been nice weather so Fiat sits. Gonna call Fiat today. Think that oil change place may have over tightened filter or maybe used wrong one.
Thanks for telling the story. Sorry it has all gone wrong for you.
If the leak was there immediately, or soon after the oil change, the 'oil change place' have responsibility to fix this. However, they will quibble, and lay some blame on you for continuing to drive after the leak was noted, so you might like to not mention that, unless pressed.
Sadly the oil pressure light serves more to show why it has all gone wrong, than to prevent the doom. The engine needs usually a minimum of 25psi to stave off serious wear, but the light will usually not illuminate until pressure drops to 5-7psi, so too late.
A likely leak point would be the filter, especailly if this is a spin-on type. When fitting this type it is important to lubricate the seal. The seal is turning as the filter seats, and a dry seal will grip, causing the rubber to create lots of minute peaks. As it warms up, these relax, leaving the filter less than tight. The pump will push the oil out very quickly.
If not already done, you need to speak to the 'oil change place' and advise them of the problem. Meanwhile do not touch the filter, or they will claim it may have been loosened after they touched it.
Once you take the car to another repairer, such as the Fiat dealer, you create a conflict between the two. The 'oil change place' will argue that they have been denied the opportunity to view and diagnose the issue, and that they are unable to determine that its current state is their responsibility, as others have touched it. Make sure any other repairer is aware of the problem before they go ahead even for diagnosis. This advice of course applies to any failure if thought to be the fault of a garage.
Sadly sounds like it will need an engine, and the 'oil change place' should be paying for that.
