getting amp wire through bulkhead IT CANT BE DONE!!!!
T
Tommy
Ive taken back the carpet on the passenger side, taken out the glovebox, bu no sign of any hole. I think it is impossible to drill a hole since there is no space on either side where there isnt something attached. Please help me, im at my last resort of going to the Fiat garage and asking for help!!!
It can be done and I'm happy to help.
Simply open up the bonnet.
on the passenger side of the car, take away the plastic trim - about 6 screws. tucked away about 6 inches away from the wing is a 2" wide grommit. Simply cut a small hole in the middle of this, run your cable thru, sillicon back up - you can get your hand up behind the glovebox and grab the cable.
I run 0 awg cable thruout my install, its an SPL car capable over 160+Db.
If you are local to Camberley, Surrey, I will be most welcome to do it for you. Email me (ANYONE) for stereo help.
Jamie
cheers jamie
sorry to be stupid, but the plastic trim on the outside of the car, just under the windscreen? (just making sure b4 i take my car to bits). It would be cheeky to ask to get some pics of your install including where your power cable comes out into the bonnet wouldn't it?!
Yup
No worries, i'll try!!
and yep the plastic bit under the windscreen - take the plastic plug off the cover for the screw on the far right of the car, then a couple of more inside, done - easy access
Jamie
N
5
498
M
3
1K
Tommy K
T
7
699
Dark Lurker
M
5
575
K
