General General Panda thoughts
Think my cat shield has been rattling. There's two eyelets at the back end which do nothing?
Firecolour suffered the same so I pulled it off. I read somewhere that is only fitted so that any exposed metal is below a certain temperature (eg 100C). As the CAT runs hotter than this, the shield provides that thermal boundary.
The car will work OK without it. Just don't park it over long dry grass after a long run :D
I have a big favour to ask of anyone on here going to Stanford, on Sunday.... :worship:
Allie ("Mrs homeward") will be coming with me; and, as yet -- because Pippin worked so well as a birthday surprise... -- knows nothing of Betty being mine. :rolleyes:
So, please, no mentions! :eek:
And, when I hand stuff over to VmanC (for Betty -- unless Panda Mo can distract Allie...), it's because he's going to spend some time on Pippin, sorting him out, later in the year.... :D
Thanks, guys and gals...! :slayer:
No problem! Mum's the word;)
Let's hope Mrs Homeward doesn't take after Panda Mo and start posting n here and then find out :eek:
Although its a pain I can't make Stanford, it's good also, as know me I'd let the cat out of the bag :eek:
As this thread has, seemingly, gone a bit sleepy, with all this sun, I thought I would stir it up a little with this....! It was the Zündspulendeckeldichtung that got me.... :D
Hello,
You are bidding on a Fiat Panda 1.2 16v converted to type 141a with the Punto 88HP!
The following new parts were installed:
- Conversion to 240mm brake system with brake booster (original 227mm) with new discs, pads, brake caliper repair kit (new piston seal, new bleeder screws, etc.)
Brake fluid was also renewed
- New steering knuckle ball joints
- New Spurstangenkòpfe
- Change the oil + filter
- Coolers
- Timing belt + water pump and idler
- Engine has been completely dismantled and overhauled by me (planned new Ventilschaftdichungen, lapped valves and checked for leaks, head gasket, valve cover gasket, Zündspulendeckeldichtung, INTAKE MANIFOLD, Exhaust manifold gasket, etc.)
- New Pieburg petrol pump (3.5 bar)
- New fuel filter
- New thermostat
- New spark plugs (original Fiat)
- New spark plug wire and ignition coils (Beru)
- Lancia Y10 Turbo Exhaust new
- H & R springs 40mm
- Bilstein shock absorbers for the front axle
- Hardness adjustable Koni dampers for the rear axle
- Lancia Y10 stabilizer stabilizer with new bearings (picture)
- 3-spoke steering wheel with 90mm coding and Momo steering wheel hub
Additional changes:
- 2 sport seats with console installed (foldable and adjustable front-back)
- 2 additional instruments in original fitted radio slot (water temp / volt)
- Sabelt 4-point harness with quick-lock
- Borbet F 7x15 Et 30 (you can get only from Aufpeis from 350 € to tires with about 60% profile tires Semperit)
I definitely still some forgotten, so just come over and make yourself a picture!
It is on this yet, but can give the homologated've already discussed everything must be just went there he wears an all!
I am selling it because I want something faster build!
The Panda has a small rust spot on the passenger door but only superficially, otherwise very well maintained since retired from hand!
Possible simply write Buy It Now
Otherwise, just let me have fun bidding and have questions :)
I'm probably going to regret asking this... -- but why...? :eek:
To help slow down all that 769cc of powa. Extra weight is what you need :devil:
EDIT: FF App fail, I thought this was the latest post :bang:
Hello,
- Coolers
- New fuel filter
- New thermostat
Additional changes:
Oh those wheels! that engine!
:bang: LHD :mad:
So a friend says to me tonight, "one of your tail-lights is out"
Fine I'll sort it later, get home, check tail lights and brakes lights both fine.
Well thats another problem successfully solved.
One day, though, you may have to resort to smacking its bottom...! :D
When I was in the convoy to Chiltern Hills, one of my brake-lights stopped working. I tried everything -- including replacing the bulb -- but to no avail.... :(
A sharp clout on the rear wing, just next to the light, by Palio, solved it immediately, of course.... :eek:
These Pandas and their moods. I dunno.... :rolleyes:
I suspect it was the edge of the light at the side - not sure I apologised for hitting Pippin :eek:
It's pretty much routine maintenance on an old car unfortunately. Sometimes bending out the tab on the bulb holder helps if it's that causing a bad connection - don't do it with the light on & using a screwdriver though as you'll only have to buy a new fuse....... :doh:
(y)
No need to apologize! You solved a problem; and Pippin obviously enjoyed it...! :devil:
:ROFLMAO:
I'd already tried that... -- before your more efficient remedy (which is still working...) -- with the ignition off. Owning a string of Mk1 and Mk2 Escorts in my long-distant youth, taught me a lot about dodgy rear lights...! :eek:
:ROFLMAO: Yes well I'd tried a shortcut on a 127 a couple of weeks before, which resulted in me having to buy some new "bullet" fuses from the 'Bay as they are not readily available in the real world. Yes it was :eek: :eek: :bang: :nutter: :shakehead: :doh: :shrug:
127's are a whole new level compared to Panda's though - possibly because they've had many more years of working out how to annoy you. I did once take a 127 with fully working lights to its MOT (a few hundred yards) to find 4 lights had gone in that distance - 3 came back with an increasingly infuriated thump, while the 4th forced me to take it apart in the middle of the MOT to get it working again - yes it passed (y)
