Hey guys.
i have a 96 model uno fire 1100.i hav minimal technical expierience and i have got a problem i was hoping some1 can give me some advice.
when i start my car and depress clutch my gears wont engage anymore.
when car is not started and clutch released the gears engage into their gears.
last night when i started car i could not find gear.after a while i got reverse gear and then i got into first but gears were very stiff.
now this morning i cant find gears when car is started or clutch is depressed at all and even when clutch is depressed fully and gear is in reverse for example i move backward instead of standing static until i release clutch slow.
can any1 tell me what is the problem?
i noticed a small leak frm above the clutch pedal months ago.it was very small.i have a feeling this may be part of the problem?
Hi there, and welcome to the forum!
Big walls of text are never inviting to read or decypher
It could well be a clutch problem not releasing.
When you say the gears do not engage, when the clutch is depressed, does the gear stick move cleanly into the gates or does it jam?
If you get someone to keep pressing the clutch up and down, if you are looking in the engine bay at the gearbox, can you see anything moving succcessfully? (note to other forum members - does anything visible actually happen when you press the clutch, or is it all internal only?)
I had a problem with first where it wouldn't go into gear unless I released the clutch a little first, then it would snap into gear, then I could release the clutch the rest of the way.
Never found what was causing that though.
I doubt it'd be the gearbox oil to be honest.
Can one of our "Seth Effrican" forum members go have a look at the car for us please?
