syncro on third gear gone. not to hard to replace. just drop the box in at a gearbox specialist. should sort quickly enough. should not cost much either.
strip your old box and take the 3rd syncr,3rd gear & syncro hub and put it in the new one. or take the 4th gear setup from the new box and put it in your old, which ever you prefer.
you must have some technical knowledge as you will have to strip the gearbox and it can get quite tricky if you do it for the first time. but just ask if you need any advise if you want to performe the job yourself.
I don't use any special tools just a normal tool set.
