Technical  Gearbox Reference
KentOveM
Stora Höga
Fiat Ducato 1.9td 1998
VIN: ZFA23000005527006
Engine: 2184977
I have a problem with the gearbox installed in the motorhome. When driving, there is a crashing sound whenever I go to lower gear. I understand that this problem could be caused by bad synchro rings. Could these be bought considering the age of the gearbox?
So I therefore trying to understand what type gearbox is installed.
As I can't find type info on the gearbox (yet), I was searching in ePer with the VIN. The OE code that came up for the gearbox is 9566526980.
Is it possible to translate that OE code to a gearbox "common name" or type, e.g. 20LE01 or ML5TU?
Regards,
Kent-Ove
You're not alone in having gearbox issues, its very common, normal even with high mileage.
A lot of times the gearboxes aren't available to buy secondhand and there's no new ones available. So you'd need the gearbox reconditioned, it will be very expensive and take a couple of weeks. You'd need to take it to a Fiat professional garage that specialises in this kind of work.
Engine: 2184977
Regards,
Kent-Ove
Hello
It cursory search online shows there may be several variations for the same transmission.
What I could find was these: 20KE01/20KE02/20KE21/20KE22
The first two appear to relate to the final drive ratio
I’ve rebuilt a few gearboxes in my time. Time consuming and costs can spiral out of control once stripped down and finding other worn components etc - would it be more effective to send yours in for rebuild to a transmission specialist?
Another route you could go down would be via an online supplier for an exchange gearbox. You are showing in 🇸🇪 ? I could not locate one there but here’s one such example in Strasbourg, France 🇫🇷 Click here
thanks very much for your answers, much appreciated.
I didn't realize that there are several possible gearboxes with the same OE number, very good information.
Well, I will need find the type identification on the actual gearbox, engraved or with similar marking. It's a sunny day in Sweden today so will try to do this today.
And yes, I have considered an exchange gearbox as you suggested. I have already received a tender from a Swedish company, cost is 3000€ for an exchange.
I must confess, work by myself on replacing e.g. the synchro rings for the gears 2-5, sounds very tempting. I have lot of time during this winter and the cost will be, hopefully, much lower than a professional repair. There are some videos out there showing ways to repair gearboxes, especially one very informative made by Rich Maxwell,
My biggest concern right now is to find the actual identification on the gearbox and of course to see if the are synchro rings available on the market at all.
I realize that I could be too optimistic about this, but I will need to give it a go.:)
The markings look like this image
which I found on this Italian breakers website Click Here
Sadly it doesn’t assist in exactly you might locate the markings, but at least you know there are some.
great, thanks a lot.
I lifted and removed left wheel, but I didn't found any text underneath and on the sides of the gearbox or the differential. There is a metal tag on the top saying PA 1687 31/08/16 and a sort of inscription on the gearbox near the clutch arm saying Ti 07756-211. So I found something but not a good clue :) as I see it.
I will continue the detective work from the top, removing the hose to the turbo etc. for a better view.
Thanks again.
OK great!
I can guess that the hose from the air filter to the turbo is in its way. It will be removed :)
thanks. for info, much appreciated.
Engine: 2184977
Is it possible, for example using a resource like нулс, to translate that OE code to a gearbox "common name" or type, e.g. 20LE01 or ML5TU?
Regards,
Kent-Ove
Your 1998 Fiat Ducato 1.9 TD with OE gearbox code 9566526980 likely has a 20KE or ML5-type gearbox. Yes, replacement synchro rings for these gearboxes are still available and can help fix the crashing when downshifting, provided the gear faces themselves aren’t excessively worn. It’s recommended to confirm the exact gearbox type by checking the stamped code on the gearbox housing, inspect the internals for wear, and then order the appropriate synchro rings or a rebuild kit. If unsure, have a transmission specialist handle the replacement to ensure proper repair.
thanks for your response and advise, I will follow your suggested steps. The plan is the remove the gearbox this week unless to much snow puts a stop on that plan.
thanks,
Kent-Ove
there were indeed problems in the gearbox. All synchro rings, except for 5th gear, were broken, 3 into halves and 1 had a big crack.
I have already replaced the rings as you can see on the picture below.
Just wondering about the root cause of this problem?
Engine: 2184977
It does sound like worn synchro rings could be the cause. Parts for older Ducato gearboxes can still be found, but availability really depends on the exact gearbox model. The OE code you found is helpful, but Fiat often uses internal numbers that don’t directly match the common gearbox names. A specialist gearbox shop or Fiat dealer should be able to match that code to the correct gearbox type. Once you have the exact model, sourcing synchros becomes a lot easier. Hope you get it sorted soon!
Thanks for your reply.
I have already got 5 new synchro rings from Transmission Online and replace the broken ones. I hope this will solve the problem, fingers crossed :)
An update and a question.
I have now replaced the broken synchro rings and have assembled the gearbox. After struggling with the small balls, which was painful, the gearbox was correctly assembled, at least I thought so. :)
But...
Before mounting the cover over the 5th gear I engaged the 5th gear.
What worries me is that you can see so much of the balls in synchro hub when the gear is engaged. It doesn't pop out, but it sure looks strange.
Please see the photo below.
Does anyone have experience with this and know if this is OK?
Thanks for your answer.
I'm pretty sure that I assembled the spacer shims as it originally was mounted. But I'll will double check. Will take som time to remove the cover ans 5th gear.
However do you see a problem with the synch balls visible?
Regards,
Kent-Ove
Regards,
Kent-Ove
I do, they look a bit exposed, so it wouldn't take much extra movement for them to drop out.
Was the bearing the same width? I was trying to think of what could cause it to be out of position.
Could that synchro hub fit the opposite was around, does it have an off set?
I have not replaced the bearing, maybe somewhat stupid of me. Anyway,
I think I have assembled the synchro hub the right way, "the wide seam" upwards.
Now, looking at som pictures, I can see that the top nut was approx. 2mm from the end of the shaft before removing. When I tightened the nut there was almost no space between the nut and the shaft, that could maybe the cause.
I will take sometime to make sure I have assembled this part of the gearbox correctly, by removing the 5th.
Thanks for your advice.
Glad you have possibly located the issue.:)
