K kppatt New member Joined May 14, 2006 Messages 5 Points 2 May 14, 2006 #1 My seicento Mia 900cc has a noise in the gearbox in 1st, 2nd and 5th gears. Has anyone go an answer as to the problem?
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 5,006 Location Liverpool May 14, 2006 #2 Check the gearbox oil level ASAP. Also, check for oil leaks from the gearbox end of the halfshaft. Then get back to us.
OP OP K kppatt New member Joined May 14, 2006 Messages 5 Points 2 May 14, 2006 #3 No oil leaks on the gearbox. Car has only done 16000 miles.
AppleSei RIP L181 VBB Joined Feb 20, 2005 Messages 16,628 Points 2,636 Location West Yorks May 14, 2006 #4 gear selector? Clutch?
SkinzCinqSporting MG ZR Owner :) Written a guide Joined Feb 11, 2006 Messages 6,866 Points 1,040 May 14, 2006 #5 General wear and tear? synchro mesh? EDIT: actually shouldn't be them with it only doing 16k
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 4,003 Location Lake District....Moist May 14, 2006 #6 Does the noise happen under load, or not. Does it happen when the clutch is depressed in any of these gears? Cheers D
OP OP K kppatt New member Joined May 14, 2006 Messages 5 Points 2 May 15, 2006 #7 still there when clutch is depresed and load makes no difference
