spookycinq
Hi not been on here for while as normally everything seems ok with new centos????
Butttttt there was a wining from gearbox which I've now replaced just to find haven't solved the wining issue?? Any ideas I'm more thinking release bearing or clutch?
Also a new problem with gears, as at 1st when put new box in couldn't get 5th or reverse, had to drive home from mates garage as they were shutting up & I've kept them behind for an hour already, got home & took the top of each box off (where all selectors are etc) to find I'd moved 1 selector without other, sorted this put all back together & got all gears but now I've got a problem of 3rd & 5th being Sooooooooo close together & the fact when put in 1st the gear stick grates on the metal around the gear stick under gater etc, if anyone has a idea of what problem is be most grateful
