7 77jm New member Joined Nov 24, 2008 Messages 39 Points 21 Jul 4, 2009 #1 Can anyone tell me where the drain & fill points for the gearbox are on my 95 1.6 90 Cabrio? Can see only one allen nut about halfway on the front - seems too low for fill & too high for drain.
wavestar New member Joined Jan 1, 2008 Messages 82 Points 31 Jul 4, 2009 #2 I think thats the fill you can see , the drain aint easy , its sort of at the bottom rear. take a look at https://www.fiatforum.com/punto-guides/102139-how-fill-gearbox-oil.html
OP OP 7 77jm New member Joined Nov 24, 2008 Messages 39 Points 21 Jul 4, 2009 #3 Nice one!!!!! Anyone know where the drain point is or shall I just top up. Will mixing oils matter? The oil has probably never been changed.
M Mdeko Established member Joined Mar 30, 2008 Messages 1,054 Points 195 Jul 4, 2009 #4 wavestar gave you info about the drain point. As said the one you a refering to is the fill point. Why is the gearbox oil low? if its lost some you must have a leak somewhere.
