Technical  Gear knob adhesive?
Jillos
Worcs
I've removed the gear knob (to replace the centre console and gear shift gaiter). What has anyone used to successfully glue back on the plastic gear knob cover? I think Fiat has used Tiger Seal - wondered if there's any cheaper options - otherwise the cost of the glue will be more than the gaiter!
Id just hold it in place with something like blue-tack then its easy if it has to come off again in the future!
Funny you should say that. OH suggested this too. I’ve bought some mounting foam tape and was going to use that, but think I’ll go for the blu tack until I’m sure it’s all on right and doesn’t pop the cable ties etc.
I just used the same silicone sealer that I use for water pumps when doing cambelts. Strong enough to hold the cap but can be levered off at a later date if necessary. Pretty much any silicone would do.
You mean - the sort you seal bathrooms with?
