Hi all.
Basically, the stilo 1.6 has started making a noise from the gearbox.
Surprisingly or not after the Mrs borrowed it to go leicester last Saturday. Sunday I went up to Rutland to see the vulcan flyby and noticed a ticking noise that increases and decreases with engine speed but only under load in all gears. If I'm cruising on mway, I.e. Not loading it to much, it's there but not bad.
The only way I can describe it is like the sound of a sewing machine.
I changed oil , checked and it did have alot of fine grains of magnetic metal, so not alloy or phosphur bronze from synchros. Im guessing a bearings failed somewhere inside and will want replacing.
Which other gearboxes will fit the 1.6 stilo? it helps broaden my search.
Any intellectual help appreciated so please dont say scrap it as I cant afford another car and why should I when everything else is OK.
