General  Fuses and Relays
Preston
My mum borrowed the cinq the other day to go to work and on her way the connection bar on the wipers came off, so i then connected it back up and when checking they worked again my wipers stopped halfway up the windscreen, and now nothing that is controlled by that stalk works, i have checked all the fuses in the fuse box and they are all fine but i havent got a clue which relay is which or if it has a fuse somewhere else, could someone please tell me which relay it is and which fuse also.
cheers Jack
got it working now, there was a fuse a must of missed when checking but the arm is vey lose on the joint in the middle so im half expecting it to do it again but i found a little rubber circle thing behind the fabric thing and i cant seem to find where that came from does anyone no if this came off that joint i tried placing it on but i cudnt seem to work out how it would go on.
cheers jack
