Technical Fuse Boxes.
Here thanks Hugh saved me a bit head scratching. That's somit I was to get today, Laminate Pouches...
Hi this is my first post.
I own a 2001 Fiat Ducato 2.8 JTD, LHD Motorhome (Dethleffs), 130,000 km on the clock, had it since new.
My horn wasn't working and there was no power to the horn itself. After searching in the engine bay and in the cab and online, I finally located the vehicle fuse box.
In the case of my vehicle, it's under a black plastic cover in the glove compartment. You simply pull it towards you and voila, there are the fuses.
Fuse 12 was blown ........... horn fixed, now I can put the vehicle thru the inspection tomorrow.
Thanks. You have located my fuse box for me. All side lights on rt side are out but can't find any blown fuse , save for a 75 amp, which surely is not for lighting.They went out when I accidentally shorted 2 cables whilst doing a repair, on my Laika motorhome..
The 75 amp fuse could feed the fuse box for several systems
This is from my 2005 ducato ace firenzy im looking to fix 12v habitation circuits as its all off, toilet lighting,toilet flush,hav 12v lights large centre light and 2 above cooker all off. Works when selecting vehicle on control panel.
No ligjts when select L for leisure.
5 amp fuse behond panel ok
Fuses left and right steering wheel ok
4 or 5 in enging centre compartment all ok
6 fuses under wardrope cupboard near charging relay all good.
Sure theres a fuse under van connected to old scabby habitation eiring before i upgraded everything.
There should be a 20A fuse, perhaps inline, close to the habitation battery positive. This is shown on your diagram.
