- Joined
- Jan 29, 2008
- Messages
- 32
- Points
- 6
Hi
Front pads were well down, almost to the plate and the front discs well worn, so out they came.
Opened the bleed nipples to avoid flipping a master cylinder seal, and pushed the pistons back in, new discs and pads. Torqued the bolts to the right torques in my book. Bled the four corners with a helper in the prescribed order. The pedal was nice and hard at the end of the bleed...
So I shut up the shed and drove her out.
With the engine running the pedal was suddenly noticibly softer and sank two inches biting progressively. The travel feels deeper and softer than before the disc change.
If I pump the pedal before starting the engine it is hard and stays high. If I keep my foot on the brake pedal and start the engine it drops away and stops about half way down to the floor.
On the road the pedal seems to go down further than in my memory but braking performance is very good and progressive, at all speeds. I can hold the car on the brakes on a slope.
Just softer, mushier, than I remember. Reminding me of a failing master cylinder on a Renault 4 I once had. Although here I dont have to pump to get good braking...
Driving a Citroen Xantia all week with its fantastic ON/OFF style brakes makes the pedal contrast even more pronounced.
I cant see how changing the pads and discs would change the biting point on the pedal travel, or is it in my mind ? I doubt I there is any air either I put half a litre of DOT 4 through each corner with no bubbles at the end.
Any ideas ?
I am going to drive it softly and watch for a change in performance. I am worried it is a master cylinder problem because of the sinking pedal thing, although I might not have notice it before, the missus drives the Multi more, but it all works fine and I dont have to pump the pedal...
Any ideas ?
