I made my Mk2 much lighter by removing my chassis.
You are going to have to take me through the finer points of the HVAC engineering, though - the Heating, Ventilation, and Air Conditioning... I don't quite see how an injector cooling fan by itself is going to cut it...!
I've never seen the plenum chamber ported out or the throttle body upgraded before... I don't think the Tipo N/A cam is a good idea. Two reasons, first you'd be better off with a 70's FIAT cam, such as an X1/9 cam, for power... and secondly, this engine is turbocharged. The cam timing is designed to be assymmetric for turbocharged engines, to avoid very-damaging compressor surge/stall under certain conditions. That's why the standard cam timing for the Turbo has such odd figures; inlet valve opens at TDC, for example, and not before. 0/40 30/10. I'm sure if the standard cam (9/31 39/1) was better, FIAT would have used it.
Presumably you're going to have an upgraded turbo on there (that is why you've ported out the plenum and enlarged the throttle?)
Anyway, keep up the good work
-Alex
Sounds good! T28 eh... I guess that's on the Mk2 manifold?
Maybe the throttle body is small to improve the low-end torque, or maybe because it doesn't have to be any bigger? Either way, with the bigger turbo and custom engine management, I'm sure you'll wring out quite a bit more power. Looking forward to the dyno plots...
I'm sure this is all going to be rather more satisfying than the pimped-out Panda - that WAS you, right?
Yeah, I think the standard heater would do a better job of demisting the windscreen, I suppose the heater was too heavy for you?
-Alex
Your project is looking fantastic!
The detail is brilliant. Nothing is original, it's all so much BETTER than original, even if the parts are standard, the paint really lifts it.
I still like those Alfa Romeo wheels, I really think this looks totally different to any other Mk2 Uno Turbo I've ever seen - for a start it has a Mk1 engine! And no heater!
Oooooh the WEIGHT of that heatshield, I'm surprised :nono:
Only joking
What a great idea with the seat cover transplant, I should keep an eye out for an earlier-style Mk1 passenger seat, then I can 'restore' my driver's seat and ditch the covers. Dunno why I'd never thought of that before - mind you, it is really hard to get the early (FIAT logo) seats in good condition (driver or passenger!)
Not long now till she's a runner? Take care, I never want to see anything bad happen to this
-Alex
Looking very good and a great thread with some real content
What's the plan for the car? Do you do this for a living or is the car for personal use? What happed the the GTV V6?
