Technical  Fuel Temp sensor Fault
helendecent
Hi Everyone
Have a French Sedici 07 which had NO DPF when I brought it ( I was unaware of this for 3 month until the engine management light came on) replaced the DPF with a like for like part, seams no problem with this. Had it replaced about 2 months ago.
Been having some trouble with a very small kangarooing every so often. Took it to the local garage who plugged her in and it came back with a Fuel Temp Sensor fault P0180.
Can anyone tell me where's about this sensor is and or anything about how much it will be to fix. do we have to replace the whole pump!
Any help would be gratefully received.
thanks
There's an old thread on these forums, here. Googling also points to the sensor being in the fuel tank, or even suggesting the issue is actually with the coolant temperature sensor...
Another point made is that it's a wiring/circuit fault rather than a faulty sensor.
Good hunting!
