Technical  Boost sensor
cooperfiat
Hi I just wondered if anyone could let me know the Bosch part number on their "turbo boost pressure" sensor otherwise known as a MAP sensor for a 1.9 diesel Sedici on a 58 plate. Its on the back of the manifold held by one M6 bolt covered up by the plastic cover plate.
The one that's supposed to fit according to 98% of the ?bay sites is different to what's on mine.
Car goes into limp mode with engine light on if I rev at 3500 plus for more than 20 seconds, all since I swapped a holed intercooler.
THANKS
Have you tried cleaning it? They are usually coked up but can be carefully cleaned out with brake cleaner & a small screwdriver.
Yeah tried that first, but still no joy.
But looking around tonight I found the rubber vacuum pipe from the bottom of the turbo to the boost solenoid split and in two pieces, temp join done for now to try it.
