General  Fuel tank capacity
hmallett
Mr Pedantic
Wales
Think you know what the fuel tank capacity on a non-4x4 model Panda is?
Think again!
According to all the specifications and the handbook, it's 35 litres. I can tell you for sure that it's not. (Technically it might be, but that's not the usable capacity)
I know this for sure, because I've given it the ultimate test!
Over the last tankful of fuel in the Panda, I have been making a real effort to drive as economically as possible. Previously I have been getting up to 63 mpg out of it - some way from the supposedly possible 75 mpg. Yesterday it got to the point where the trip computer said I had got to 69.2 mpg, but the low fuel light was on. I knew from previous experience that even when the needle was on empty, there was room for 30 litres of fuel in the tank. With a quoted capacity of 35 litres, this would mean that there was about a gallon of fuel left - enough for quite some distance. So I pushed my luck a bit. On my way home from work, I could have stopped in Wrexham, but I had only done about 497 miles on the tankful by this point, and I wanted to get more than 500. So I carried on, planning to fill up at Shell in Oswestry. About half a mile from the petrol station, coming out of a roundabout, the car shuddered, and the engine stopped. There was no more fuel.
Luckily there is another petrol station about 100 metres after the roundabout, and I had enough momentum to get me to this point, and off the main road. I coasted round towards the pumps, and came to a stop about 10 metres short! I got out the car and tried to push it to the pump, but due to it being a slight uphill slope it was very hard work. Luckily there was a member of staff there to give me a push.
I filled the car up to the brim. It took 32.5 litres. So Fiat’s quoted capacity is wrong. At least this explains why it ran out sooner than I thought. Still, it works out at 69.1 mpg, which isn’t too bad.
The engine started after about 2 seconds of cranking, but the engine management light stayed on. The car ran fine though.
The next day I rang the dealer to get the engine management light sorted. Unfortunately their code reader was broken, and a new one was on order, but not available until May, so I booked the car in for May 5th.
Of course the next time I started the car, the light went off…
H
At the pump itself was flat. It was just a slight slope up to the pump for the last 10 metres.
I did tip the guy who gave me a push. The tip I gave him was "Push the car more quickly when people are impatient" :p
H
Very interesting thing you are discovered, hmallet... I'm interested too in the real capacity of my Panda's 4x4 fuel tank.
btw: This is one a bit disappointing thing with the 4x4 Panda - you need to tank every 300 kms or so; I have only 3300 km on spydo yet, and the dealer says, that in beginnig is normally the consumption higher than expected and should normalize before 5000 kms (has anybody any thougths/experience about this subject?). Official Tank capacity for 4x4 is 30 l, and the last 5 l are in fuel empty warning lamp on zone - so i have 25 l fuel form "lamp to lamp". And, since the 4x4 consumpts at yet 8,4 l/100km in town and 6,8 out of town in average (it's by driving rather soft, than hard/sporty), it's hard to adapt to visit Tankstelle so often.
So - I were happy to know the actual amount of the remaining fuel after the warning light goes on - if, as in your case, hmallet, I have just 2,5 litres instead of 5, it's really simple to stuck in a midddle of forest / sump_road with no expectations on any bypasssing car in same day...
I think there's about 5 litres remaining once the light comes on. I assumed before that if there was a 35 litre tank, then the reserve capacity was about 7.5 litres.
Unfortunately it was 5 litres of reserve, and the tank only held 32.5 litres. :eek:
H
I've filled our panda 4x4 (1.2 petrol) up a few times - once from low enough for the computer to stop indicating how many miles left to run ...I managed to get 31 litres in the tank that time without really trying to brim it - which isn't bad given the quoted 30 litre capacity.
In terms of mpg - I don't normally drive it ..but I took it to work this week a couple of times...the journey (50 miles each way) ranged from some short A road and approx 25 miles on m/w (at 80 - 85 mph) ..then about 15 miles through town. On the way back I went A road all the way....mpg was just short of 40mpg (or 7.1litres /100km) for the days journey. I've used the car again this week and today and the av mpg hasn't dropped below 39.5mpg.
Given this is a mix of m/way and town driving I'm quite suprised (pleasantly!) ....btw the car has 2700 miles on the clock and is 6 months old.
7.1 l/100 kms in mixed cycle - sounds similar to my experience... btw - i cant get the Fiats claimed 5.8 (out of town) even in "on_the_fly" readings...
I know on trucks that the lift point for the fuel is a lot higher on a diesel than say on a petrol, this is set this way as diesel is a far less refined and can often be quite dirty.
H, i'm not sure about the Panda, but some cars have a cut out fitted to stop the fuel pump air locking through lack of fuel. our Mazda is fitted with such a devise. If the system air locks it can be a pure BAST*** to sort.
It may well be that you are correct in saying the tank may well hold 35 litres but due to the lift point you only have 32.5 of usablel fuel
Ian
Just checked the receipt, and it's actually 33.5 litres, not 32.5. Unfortunately I can't edit my original post. :eek:
Ian, I remember on my parents Tipo it had a rubber bulb somewhere that had to be pumped if the fuel ran out in order to re-prime the system. Before trying to restart the Panda I checked the handbook to see if there was anything similar, but it didn't even warn you not to run out of fuel, so I just turned the key, and it started after about 2 seconds instead of the usual 1 second.
H
The Panda tank is much too small. I should have added that to my list of niggles. We refill ours every 270 miles ( ish ) regardless of whether or not it is nearly empty.
I would be happy with 270 miles (434,5 km). The 4x4 has a 5 l smaler fuel tank as the 4x2 version due to extra space needed for the transmission to the rear wheels. and 25 l (30 - 5 reserve) give me usual 300 - 330 kms (185 - 200 miles) from warning light to warning light :( And that really isn't much...
But - ofc, I was in course about that thing - so - no complaints to Panda/Fiat. I still love this car :)
So the 4x4 is quoted as 30 litres, but you can get 31 litres in easily, but the non-4x4 is quoted as 35 litres, but is only 33.5 litres from empty to full. I wonder if in fact there is no difference at all between the 4x4 and the non 4x4 :confused:
Would any 4x4 owner like to run their tank dry to find out? :p
At least I now know not to run out again, though I can get over 500 miles (805km) out of one tank. :D
H
H
500 miles :eek: that's really good. I assume, youre driving very carefully, hmallet :)
It was 500 very slow, gentle, boring miles... :p
I just wanted to see if it could be done.
H
Is this petrol you are all talking about?
In my new 1.2 Dynamic (approx 400 miles on the clock) the Mrs seems to be filling it up once a week and that's only about 5 miles there and back to work and the odd trip down Tescos. If it wasn't for the locking petrol cap, I would think someone is making away with the stuff in the night.
I have explained to her that it has got 5 forward gears - and it's good to check them all out once in a while - so I trust it's not going everywhere in 2nd.
Let's hope things improve as the car runs in ......
When new, my 4x4 (with slidey rear seat) was only doing 35 mpg. I only drive in town, and usually the same 14 mile journey. Now we're up to nearly 1000 miles the consumption has dropped to 37-38 mpg, which is much better. I'd still like a diesel, but still no 4x4 Multijet in the Uk. I expect to get 40+ on a longer journey, but the stop-start driving I do probably means I'll spend more on clutches than on gas over the life of the car...
My 1.2 4x4 has done around 1400 miles. On motorway trips at 70-75 mph I tend to get between 30-35mpg, with 31 being the norm. I take it as the miles increase and the engine beds in I can expect a wee increase?
It's not on the motorway a lot, but it'd be nice to get above 35mpg eventually!
Other than that I'm very happy indeed with the car. The range is obviously limited (I'm lucky to get 200 miles from a tank at the moment), but I love the car and it is so much fun to drive...
Roll on winter! :D
Roll on winter! :D
200 from a tank??
i put 20 quid in mine and get 193:eek: miles is my best so far. i will stick a pic to prove it!!
