hi folks not been here for a while, i need some help please.
i have a ducato 2.3 multijet 2007 motorhome, it developed a diesel leak a while back i have discovered the leak is at the snap connector joint in the fuel feed from filter to injector pump, its the join just below the starter motor where the feed and return pipes both have snap connectors.
anyway i have reason to believe it only leaks when engine is on overrun ie when going down hill or approaching junctions, roundabouts etc, its fuel is being forced back down feed pipe from HP Pump and finding the weakest link which is snap connector joint.
i have no warning light on vehicle runs perfectly no smoke, starts easily,
im wondering if fault could be suction regulator valve in HP Pump,
hope ive made some sense here and appreciate any advice and help
Thanks Eric
Thanks Eric
