fuel indicator on dashboard
dejan
hi, i have problems with fuel indicator on my fiat marea 1.6, it almost always at minimum, even if there is tank full.
Does anybody knows wheres the problem?
ps.
sorry about my english.
Fauly Fuel Sender Unit
Dejan, It is probably the fuel sender unit. I think that the sender is the same on the Marea and is part of the fuel pump unit which is in the fuel tank. It is an all in one change I am afriad.
There is a write up on the Bravo Guide telling how to change it
http://www.bravo-guide.co.uk/fix-a-bravo
Good luck
Nige
tap the dash..
Mine does the same every once and a while..tap the dash and it will return to normal..
S
1
6K
Streak2013
S
J
580
J
F
7K
F1-ANG
F
T
1
571
Joseph
J
E
892
E
