fuel cut off
fuel cut off
M
mat
Does anyone know where the fuel cut off switch is on a 100 16v.I have no manual.
Should be under the passenger seat under a plastic cover with a rubber bit on top.
Re: Re: fuel cut off
Mine was behind n/s kick panel has a hole to stick your finger through to press.
Paul
Re: Re: Re: fuel cut off
On your drivers sun blind there is a load of text advising you that the car is equipped with a fuel cut off switch. It should also tell you where it is.
N
S
1
6K
Streak2013
S
T
1
631
Joseph
J
O
3
403
K
