Re: LB's Fuel Consumption
Louie Bee said:
I spent a lot of time slipstreaming lorries
until a Mc Donald’s lorry had a pop at ramming me off the road near the M6 Knutsford junction
Within the journey, I did some off roading too which will have taken the MPG down a tad
Louie...
I was really laughing out loud...
We have discussed your aggressive driving before, y'know
I even know where the Knutsford M6 junction is.
And... I like that reference to 'off roading' within the journey! as though that would be a natural consequence of the driving...
Anyway for those of us that stay on the road, I think 7.5L/100km (37mpg) would be a reasonable value to expect for average around-town driving. I used to get that with my old Uno 60 (1116cc). 999cc FIRE should be a little more economical - perhaps up to 6.5L/100km (44mpg).
Cybermunky:
If economy is worse than this, check the engine timing (including vacuum advance) and the spark plugs (as already pointed out). But also, try pushing the car by hand on a flat surface. It should be quite easy to roll (brakes not binding, tyres inflated to 30psi - although 27.5psi is the recommended pressure).
Make sure your economy measurement is accurate by filling the tank consistently to the second 'click' of the fuel pump's auto shutoff, and perhaps even verify that the odometer is correct over a known distance.
Ensure that the engine is warming up properly within a few kilometres (temperature gauge reading 80-90, about halfway). Thermostat stuck open is a common fault. Also inspect choke mechanism to ensure choke is 'off', and ideally check carburettor float level to ensure that there is no flooding. Is the engine easy to start?
With petrol prices the way they are - I hope you find an answer...
-Alex
