Well its a 1993 Uno 1.0 i.e. with an '89 block+head+dizzy with '93 SPI+CAT+Exhaust and a K&N filter fitted
Just failed its MOT on emissions results as follows
[oh and a front flexi brake hose, but that's easy to fix]
FAST IDLE TEST
Description . . Min . . .Max . . . Actual
CO . . . . . . ----- . . 0.300 . . 0.519 FAILED
HC . . . . . . ----- . . 200 . . . 100 PASS
Lambda . . . 0.970 . . 1.030 . . 1.011 PASS
SECOND FAST IDLE TEST
CO . . . . . . ----- . . 0.300 . . 0.600 FAILED
HC . . . . . . ----- . . 200 . . . 98 PASS
Lambda . . . 0.970 . . 1.030 . . 1.006 PASS
NATURAL IDLE TEST
CO . . . . . . ----- . . 0.350 . . 0.464 FAILED
So the CO is beyond the limit on every test
The MOT Tester suggests it needs a new CAT
Found one on line for £75
BUT want to be sure this is going to fix the problem before I spend any money
What do you all think?
FAST IDLE TEST
NATURAL IDLE TEST
