FTAO TOM
FTAO TOM
A
Anonymous
tom or any 1 here is a quickie.
had my car lowered and i had a look at my left arch the other day. and noticed that the spring was rubbin on my inner arch :s and has scrtched it to bear metal. is this bad and how do i stop it.
was thinking of hitting the spot with a hammer just to move it about half a cm. and that should stop it. wat u think.
Smee
Check the springs are fitted correctly, that should not happen.
Re: Re: FTAO TOM
i took it back to holborns at it looks fine they said. wat should i do its only the left front.
Smee
Re: Re: Re: FTAO TOM
will nockin it half a cm be ok it should stop it from touchin. cos i hear if its touchin it will fail it mot. so i really need to know what to do :S
Smee
Re: Re: Re: Re: FTAO TOM
The inner wing is structural, hitting it will weaken it.
Do you have a haynes manual?
Re: Re: Re: Re: Re: FTAO TOM
no i dont, my mate does. ill show u a pic when i get 1 or ill draw a primative one on paint for u
it like the size of a coke bottle top maybe a smidgin bigger, and the spring is rubbing on the inner wing as it goes up or down or something. wat do u recommend?? really cos if its an mot failer then im screwed. so help realy needed.
Smee
Re: Re: Re: Re: Re: Re: FTAO TOM
Look at the pics in the haynes manual and make sure the spring is seated correctly.
Re: Re: Re: Re: Re: Re: Re: FTAO TOM
ok. ill have a look but i thought it only went on 1 way???? also. say i did look and the spring was sittin correctly then wat should i nock it or not??? i really dont know
Smee
Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
well i dont nkow what to do tom. when i get it back can i book it in with u and u can look ir something cos norfolkite dont have a clue and frankly neither do i.
Smee
well i dont know what to do tom. when i get it back ill take it back to holburns and get them to look at it. if they cant find anything can i book it in with u and u can look or something cos norfolkite's dont have a clue and frankly neither do i.
Smee
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
i cant see anything in my book i have here (not haynes) every thing looks sweet. just catches for un known reasons.
Is it a mot failure or not for the rubbin. cos if not i aint bothered cos i cant see it do much harm.......
Smee
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
if its taking the paint off under teh wheel arch then it will rust/rott like hell come winter, you need it sorting one way or another!
Can't see it being an MOT failure, they won't be testing it to full travel anyway.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
ok ill take it back to holburns get them to look, but if its not that wat do i do??? i cant leave it like u say. it will rust i need to sort it, and i can only nock it. :( only need half a cm max. and then wat do i do to stop it rusting??? wat primer and paint do i use or is there special under arch paint.
Thanks Smee
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
ok thanks tom ur a star. ill still get it painted, and i hope they have fitted them wrong cos they can replace the spring if damaged
Smee
Its galvanised, it should not rust.
I still think they have fitted something wrong.
as tom says i wouldn't knock it as theres a problem, alering the car isn't solving the problem. If it's rubbing a lot it will rust, it's italian! :)
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
alan dont say that. :( dont want it to rust on me. shes only 2 yrs old and her next birthday isnt till september, i dont want her to have early retirment.
well i dont have a clue wat to do cos if its fitted correct then i must have a defect in the arch its self thus i have no choice to nock is do i??? and I AINT PUTTING STOCK SPRING BACK ON!!!!!
Smee
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: FTAO TOM
Lee ya tool, stop wettin yaself.
Didnt Gareth say its the spring?? its slightly over sized - bit wider than the OE spring?? (tho it shouldnt be) - i'll get matty to check it sat. make him take the whole shock out, check the seating of the spring and re-fit the shock.
If not i'll take a grinder to ya spring and make it slimmer ;) lol
Adam
S
3
242
stephen01
S
T
Tom
2
431
S
S
7
393
S
B
17
502
Dark Lurker
