General  Frozen open
General  Frozen open
msT
Couple of times now my doors have frozen in a way that the catch doesn't trigger so door stays open and windows won't open (even on one clear of frost and ice). Takes a good half hour to defrost my car.
It's my first winter driving, any tips to help speed this up or prevent it? I use de-icer but today even that froze! It was quite interesting, it turned instantly into little icey balls.
The corner seal of the drivers door is a bit warped, not entirely sure what to do with that, could that be letting more cold in making it worse?
I have a 2002 multipla.
I've had this too, the handle hinge (Small diameter rod holding two halves together) gets crud on it and eventually the spring isn't strong enough to pull the handle back.
I ended up taking the handle off (careful with the small white plastic actuating rod retainer), taking it apart, cleaning it up, greasing it and putting it back together.
