Technical  front lights
taz69
please please please can any one help me had a front end bump and damaged both of my front light clusters will brovo/a lights fit i have a 2.4 deisel marea weekend and i finding it hard to locate some more lights without going to a main dealer:confused:
What type of lights do you have, don't forget there are two types fitted to the Marea, you will either have the same ones fitted to a bravo/a (which I believe are on 1.6 and low spec 1.8 Mareas) or you will have polyelipitical which basically have a lense inside the lense (if that makes sense)
The cheapest place to get them is Ebay about £50-£70 a side, I think standard Bravo/a ones are easier to come by as it took me ages to find a RH side Polyelipitical one! The Bravo/a ones will go straight in if you have a lower spec Marea, however if its higher specced with Polyelipitical headlights and you want to fit Bravo/a headlights then I believe you have to change some connectors around and stuff.
From a main stealer headlights are £165+VAT each!
There are some online places that do them for about £110+VAT and postage.
Hope that helps and I haven't confused you! :D
