Styling  Front Grill
Styling  Front Grill
gholian
Galway, Ireland.
I was looking into buying a front grill for a Mk1 Uno. I was looking at the one with spot lights on the grill. The lights themselves are cheap enough but the problem is postage from the UK to Southern Ireland. How heavy do you recon those grills are?. The guy says it will weigh 10Kg when packed and cost £24 to send to Ireland by Surface post which sounds a lot of weight for a piece of plastic and two lights.
the grille itself is not very heavy as you say, i had a turbo grille sent in the post which didnt cost much, but the lamps are slightly different, i've just check a couple of foggys i have which i imagine aren't too different, they go under the bumper as opposed to in the grille, and they both do weigh a bit, being old-tech glass, unlike the newer poly-carbonate ones, you may have to bite the bullet on this one, besides from what i understand those grilles are a bit rare!
