Technical  Front fog light problem?
RossiUK
Hi Guys
bought a 2007 3dr Grande Punto 1.4 Active Sporting yesterday, and noticed i cant get my front fog lights to turn on.
So first, with out trying to sound silly how do you turn them on? im guessing they come on when the headlights are on full beam?
secondly, what should i check before i take it back?
i would take it back tomorrow but the person i need to see isnt back in till Wednesday.
If its something easy then i would rather do it myself
Thanks guys, and great site :D
Switch for the front fogs is to the right of the steering wheel beside the headlamps level adjuster buttons. Top one for front lamps and bottom for the rear lamp. If that doesnt work its bulbs and fuses check time !
Hope this helps.
Thanks for the quick reply guys, just tried that, and i got nothing.
Im assuming they are fitted (do they come as standard on my model?) as there are bulbs there, and looking at the fuse box, aslong as im reading it the right way, F31 has a 7.5 Fuse in, and it should be a 20. but thats only if im reading it right :eek:
Make sure you are at the right fuse before you change it ! Sounds like they are fitted if the
Switch and lamps are there !
No, i wouldnt change any of that without making sure i was changing the correct fuse.
i would upload a picture of the fuse box, or use a picture i found on this site, but it wont let me just yet.
is it possible for someone to post a picture with a arrow pointing the fuse i need to check?
Thanks very much for your help (y)
Can't at the moment mate but if it can wait until tomorrow I can take a pick of the manual if that would help ? Or unless anyone else might oblige :*)
Its fuse no30 in the fusebox in the engine compartment beside the battery. I can't get the picture to upload but almost in the centre there are two rows of fuses
Its the second one from the bottom in the left Row. It should be a 15 amp fuse.
Sorry I can't get the picture on !
Lesson learned ,no matter where you buy a car ,check everything before you take it ,Just take it back ,the dealer should have picked it up when checking it over before you collected it ..Hope there isn't anything else wrong with the car ,as it doesn't sound as though it was checked
