Finally, we could move away from camber bolts!
http://www.ebay.co.uk/itm/Camber-Pl...128?pt=LH_DefaultDomain_3&hash=item4ae4c63618
Great price as well!
"Pins are longer than the original pads, which allows you to mount a decent struts.
Installation on a plug & play is very simple.
On the damper is applied to the plate spring,
then the shock is applied to sleeve and further CAMBER PLATES then turns everything nut with washer.
Suitable for any suspension, which are mounted on factory pads for fiat cinquecento and seicento"
The damper bit is something i am not entirely sure about. Also will these plate just replace the existing top mounts?
Ming
Ming
