Technical  Front Bumper removal
Lanarkshire
How easy a job is it to get the front bumper off and back on again?
I am pretty hands on with things like this but is it something that should go to plan with not many things going wrong?
I plan to remove the current 'plastic' parts of the grill(s) and replace them with some honeycomb grill similar to the Golf GTi or the picture below.....
eLearn - Contents NUOVA BRAVO 1.4 16v R.R. FRONT BUMPER 7210E10
198001080.image
20.image
Removing ( Refitting ) - Position the vehicle on a lift.
- Raise the vehicle.
1. Working on both sides of the bumper, disconnect the electrical connections for the fog lights.
Description
Connector
1
LEFT FOG LIGHT
See F015 LEFT FOG LAMP
1
RIGHT FOG LIGHT
See F016 RIGHT FOG LAMP
198001081.image
1. Undo the lower bolts fixing the bumper.
198001759.image
1. Working on both sides of the vehicle, undo the bolts fixing the wheel arch.
2. Undo the bolts fixing the bumper to the wings.
198002641.image
1. Move the front edge (1a) of the left front wheel arch.
2. Disconnect the headlamp washer supply pipe (2b) from the pump (2a).
198001083.image
- Lower the vehicle.
1. Undo the upper bolts fixing the bumper.
198001084.image
1. Release the side ends (1a) of the bumper from the retainers (1b).
2. Remove the front bumper.
- If necessary, dismantle the bumper.
Op. 7205E10 STRIPPING FRONT BUMPER
21.image
Refitting ( Removing ) - Check that the bumper is not damaged.
- Position the bumper and fit in its seat, doing up the side retainers.
- Tighten the upper bolts fixing the bumper.
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
- Connect the headlamp washer supply pipe to the pump.
- Tighten the bolts fixing the bumper to the wings.
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
- Tighten the wheel arch retaining bolts.
- Tighten the lower bolts fixing the bumper.
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
- Connect the electrical connection for the fog light.
- Remove the vehicle from the lift.
198001080.image
20.image
Description
Connector
1
LEFT FOG LIGHT
1
RIGHT FOG LIGHT
198001081.image
198001759.image
198002641.image
198001083.image
198001084.image
21.image
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
Component
Fastening
dia
Value (daNm)
Validity
front bumper
Bolt
M6
0.6 ÷ 1.0
Thanks mate (y)
I know how to do it though but I was just wondering if anyone else had done it and from experience were able to tell me whether it is as simple as it should be.
Or am I going to be loosing the head a lot :D
