Strangely enough we still actually like the car, despite all the problems we have had - so its not all bad news.
Any response would be appreciated.
Many thanks
Tony
I thought you were only supposed to rely on these oil level sensors from cold (or when the car has had a chance to stand for a while) because of the movement of the oil otherwise, in the same way as you wouldn't use a dipstick on a car when then engine has just been run......poggy said:On the oil level light, mine often gives different levels if I have just been driving the car. Probably because it takes a while for the oil to flow back down into the sump where it is measured.
Very good point! I only tend to look at indicator once starting from fresh in the morning, at all other times I don't even look tbh due to fact engine already been running.John_K said:I thought you were only supposed to rely on these oil level sensors from cold (or when the car has had a chance to stand for a while) because of the movement of the oil otherwise, in the same way as you wouldn't use a dipstick on a car when then engine has just been run......
HiStuart DemonD said:Very good point! I only tend to look at indicator once starting from fresh in the morning, at all other times I don't even look tbh due to fact engine already been running.
HiLou said:The nav locking up is something I have experienced recently, there is a thread about this under my name. Mine always happens at the same geographical location (South Mimms Rondabout). At first I was stopping the car to reboot the system but then i found that ejecting the Nav CD also worked.
Hishrek said:Welcome to the forum Tony,
I'll be interested in what the dealer says when you've had a second opinion on the discs/ pads.
Replacing them is a common rip off by dealers.
If you replace a set of discs then the pads should also be replaced.
Shrek
