V vinny55 Member Joined Oct 16, 2019 Messages 13 Points 55 Nov 14, 2019 #1 Fog lights not switching on relay clicking but where is relay
C Communicator Prominent member Joined Aug 3, 2019 Messages 3,341 Points 908 Nov 14, 2019 #2 You have not given the version of your Ducato. In my 2006 x244, the foglight relay and fuse are located in the engine bay fusebox. This info is given in the Fiat Manual if your relay is in a different location.
OP OP V vinny55 Member Joined Oct 16, 2019 Messages 13 Points 55 Nov 14, 2019 #3 Communicator said: You have not given the version of your Ducato. In my 2006 x244, the foglight relay and fuse are located in the engine bay fusebox. This info is given in the Fiat Manual if your relay is in a different location. Click to expand... Sorry 1995,nothing in the manual about relays
C Communicator Prominent member Joined Aug 3, 2019 Messages 3,341 Points 908 Nov 14, 2019 #4 In the past I owned a 1990 Talbot Express, which was also a Seval manufactured vehicle. This had relays hidden behind the instrument panel. Hope that this helps.
