Technical Fog Light Loom
tcwobble
I know there are similar threads but none that answer my query. I own a 2013 Ducato 130 Motorhome, x250 standard I believe. I want to install front Fog Lights however there appears to be a misunderstanding as to whether or not the Looms are pre-installed. I had the vehicle for it's annual service last week and asked the Fiat agent to confirm or otherwise that the Looms were present, the answer was an emphatic 'No'. Anyway when I returned home I decided to have a look myself and discovered that there are indeed some terminated Looms present but no ID to indicate what they are. Please see photos. I' be very much obliged if someone could shed some light on this issue (please excuse the pun).
https://www.dropbox.com/s/ws4tdyapusevam7/view into engine compartmet RH side from above.jpg?dl=0
https://www.dropbox.com/s/z9n2tqz5t61u59z/view from underneath nearside behind wheel.jpg?dl=0
https://www.dropbox.com/s/b9rfd5r36h7ff04/view into engine compartment RH side from above..jpg?dl=0
Regards,
tcwobble
Regards,
tcwobble
hi is the wrong ecu that's what fiat told me when I went a few years back even for the same thing though the wires are there so just fitted day running lights
Thank you Syldale, I'm presuming ECU means Electronic Control Unit? Is it too much to ask as to the details of your DLR installation?
Regards,
tcwobble
Regards,
tcwobble
hi did mine years ago run it straight from vehicle battery with fuse & illuminated switch but I have seen aftermarket ones I think on ebay about £60 which just fit into your existing loom hope this helps
