General  Flashing mileage - failed Proxi alignment
Mad one
As per title, Qubo has had flashing mileage for a week or so, no other symptoms until yesterday.....when I was miles away working and wife had doctors appointment....car refused point blank to start...... wife not happy bunny!!
So one fault for battery disconnects, battery reading 8.5 v.... one new battery later , car starts first time, however mileage still flashing, so as had multicusan out any way, carried out alignment...failed,
Failing for “convergence telematic mode (CTM)
Anybody have any idea what the heck that is?
Everting now seems to be working fine, however need to get rid of that flashing mileage.....
Over to you all.......
Hi.:)
Do check the charging circuit..
8.5v : 4 out of 6 battery cells :(
Fault code : C----
Give us a clue.. ;)
Charlie
Hi Charlie,
Cleared fault which was battery disconnect before noting the actual code...... sorry... however on parameter check it was 8.6 v so changed battery.
Everything, and I mean everything, seems to work, including the radio, all steering wheel controls , Bluetooth etc . I just have the flashing mileage and cannot complete a Proxy Alignment as I said.
Oops, just rechecked and done further searches across fiat forums, the Bluetooth etc. Does NOT work..... suspect it’s the blue and me unit....radio itself is fine...... might just live with the flashing mileage...
As for the battery, the one I took out that had been replaced itself ( by a garage ) some 2 years ago was not a stop start type, so that may be why it failed? The charging circuit indicates a steady 14.3v with only slight dip when everting on load ( multiescan graphs whilst driving)
