Tiger Seal would do the best job, not sure Silicone sealant would hold them on very well. It is possible to remove items stuck with Tiger Seal but you won't get it off your paint without damaging it. Might it be possible to use double sided badge tape?
Do Fiat not still sell the fixings?
I can't see how you'd do a non-permanent (and neat) job without drilling the door and using the fixings myself...
Isn't the hole in the door only big enough for the top bit to go through? The trim then slides onto the gap which is now just outside the door? Trim holds the plastic bit in place and the plastic bit holds the trim tight to the door. I'm guessing so it could be twaddle......![]()
The clips work like a rivet. You put the fat end (at the top of the photo) into the hole in the door and tap the other end into it. That expands the fat end so it is held tight, similar to the clips used for the rear arch protectors. The trim then slides into the clip.
Otherwise, try here...?![]()
I get mine from the main dealer, they're not cheap but it's convenient and probably no more than anywhere else.
If you like I'll check I have enough and sell you some of mine ( cost price ) rather than you having to buy more than you need. Plus to save you postage, I'll pop them in with Pinky's exhaust rubber.
That would be great, thanks.
Total number of holes is 16 if you can spare it, if not will make do with whatever you can spare.
Also have you got some new plugs for the rear stone protector, could do with 4 of those if you have them as mine didn't survive been removed very well.
Thanks Vernon :worship:
CLS, I have some spare secondhand clips I could post to you if you're looking to save £. I've fitted them in the past to doors (like yours) which don't have the pre-drilled holes. Method: cut the plugs off the clips so that the clips will now sit flush to the door. Drill or push out the remaining part of the plug from the clip (so there is now a hole in the middle). Use a self tapper to attach this to the door (have drilled a small pilot hole). Works quite well. Handy to have the measurements from an existing door to know where to place the clips.
Let me know if you want some!
David
