S spud m New member Joined Sep 25, 2007 Messages 4 Points 1 Sep 27, 2007 #1 help me please i have a fizz 1.0 with fire eng can not get oxygen below 9.3 at idle high r p m down to only 5.3 thank you
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,591 Points 11,024 Location Edinburgh Sep 27, 2007 #2 what have you tried so far?
OP OP S spud m New member Joined Sep 25, 2007 Messages 4 Points 1 Sep 27, 2007 #3 a new oxygen sencer
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,591 Points 11,024 Location Edinburgh Sep 27, 2007 #4 had the cat checked? tried fuel cleaner? tried taking it for a good long drive? is the car fully warmed up when the test is done?
custard Status: DEFCON Grumpy Written 10+ guides Uploaded 5 resources/downloads Joined Nov 4, 2003 Messages 48,591 Points 11,024 Location Edinburgh Sep 27, 2007 #6 when i say warmed up i mean cat temp not engine temp. the long run takes care of this,the cat needs to get nice and hot
OP OP S spud m New member Joined Sep 25, 2007 Messages 4 Points 1 Sep 27, 2007 #7 all very hot and at full temp
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,853 Location Durham Sep 28, 2007 #8 it helps a lot if you can tell me the results for co, hc & lambda. check carefully for an exhaust leak before the lambda.
