could you tell me how it looks like?Exactly as sixpotman said. Take care with the exhaust cam pulley because the camshaft sensor is underneath it and if the thin metal inside of the pulley bents you will have to straighten it.
could you tell me how it looks like?Just be careful you don't bend the metal timing ring
inside the alloy cam wheel, if you have to remove
the exhaust cam wheel. It will chew the timing sensor
and engine won't run.
could you tell me where can I find the torque values for all the nuts and boltsIt looks so easy with the engine on a stand..
It reminds me... get the longest 15mm spanner you can.. the aux-belt tensioner needs a lot of leverage.
Ralf S.
could you tell me where can I find the torque values for all the nuts and bolts)
thank you!Crankshaft pulley bolts
21-26 Nm 15-19 lb.ft
Timing belt tensioner nut
24-29 Nm 18-21 lb.ft
Balance belt nut
12 Nm 9 lb.ft
Inlet camshaft pulley bolts
12 Nm 9 lb.ft
Exhaust camshaft pulley bolt
100-124 Nm 74-91 lb.ft
Camshaft bearing cap bolts
13-16 Nm 10-12 lb.ft
Valve cover and timing belt cover bolts
9 Nm 7 lb.ft
Water pump bolts
17-21 Nm 13-15 lb.ft
Variator solenoid bolts
14-20 Nm 10-15 lb.ft
It a thin metal ring with a reference piece missing,it won't come off, it's part of the pulley.it tells the sensor what position the cam shaft is.
this is the ring I should be taking care of? View attachment 192065
