Fixed rear lock, nuff said..
P
PeteIreland
For those who may be interested this is how I fixed my rear lock...It was seized for the last 3 months...local mechanic said that it was seized and had to be replaced...local Fiat dealership wanted €200 for the job...
1.Open up rear hatch.
2.Remove four retaining screws that hold the plastic cover in place
3.Remove the cover taking care not to break the studs that keep it in place
4.Now you should be able to see the barrell of the lock itself.
5.Get some good quality car grease and cover your car key and key slot liberally with it.
6.As you look at the barrell from inside the rear hatch you should see a little square block(at the 12 o clock position)which I think keeps the return spring in place
7.Now insert the key into the lock,before turning the lock push this little square block to the 1 o clock position.You should now bw able to turn you key freely within the barrell
8.Keep doing this until you think it feels really smooth.
9.I also covered the outside of the barrell in lots of grease as water from the rear spray can sometimes leak on it when it pops off the nozzle..its happened to me.
10.Roberts your mothers brother!!!!!
Re: Re: Fixed rear lock, nuff said..
are u talkin abt the boot lock coz mine isnt workin wen i turn the key, i hav 2 open it with the lever in the front!?
Adam
Re: Re: Re: Fixed rear lock, nuff said..
Yep....Sure am Adam
Re: Re: Re: Re: Fixed rear lock, nuff said..
Good write up there m8...
havent had the problem myself, but i expect to get it :)
Speak to Wimmy, and ask him to put it on the bravo-guide...
Daz
Re: Re: Re: Re: Re: Fixed rear lock, nuff said..
nice write up, ill be doing that, wondered why the c**t wouldnt open with the key, its a right get opening the car an pullin the lever! cheers mate ill give it a go!
Nice one
Nice one peteireland!
I believe many have this problem. I didn't even think that it worked when i first bought my bravo?!
Ollie
Re: Nice one
Thanks Ollie...anyone have Daz's e-mail addy??
Re: Re: Nice one
Sorry guys and gals..having a bit of a blonde moment...I'll bung Wimmy an e-mail..don't need Daz's addy...ta :-')
P
2
527
Joske
J
B
643
Brian
B
L
1
726
K
T
6
2K
K
