i fitted them on a sei, which is very similer
if they are the ones that plug into fag lighter then they very easy to fit
its best to lay the neons on on the ground before you put them on as there is a right and wrong way to put them on
what i did is drill into the car and use self tapping screws to fix the brackets securely, i covered the screws in vaseline before i screwed them up, i hoped the vaseline would act as a barrier to stop any rust
make sure you also have plenty of cable ties cause you dont want wires dangling or wires getting caught in anything
it shouldnt take long to fit them as there is very little wiring up to do, you just have to connect everything up and away you go
good luck, you should be able to do them in a couple of hours
make sure you hide the tubes as best as possible, cause they will look awful otherwise
*if they are not the fag lighter ones, the method of fixing them to the car will be the same, but you will have to wire them direct to the battery, via a switch and fuse, you will aslo need to find a suitable earthing point
