Technical Fitting “Abarth” rocker cover on 650
So, I’m test fitting things before starting the actual rebuild process and have discovered that the “Abarth” rocker cover hits the Weber imb28 when attempting to mount. I sanded away a little but it still is not enough. Thoughts?
You will be surprised as to how much you DO need to file away!---a Dremel comes in very handy in this situation. Seriously though, yes there is a fair bit of 'fettling' required to give clearance. Luckily, the 'pattern' rocker covers seem to have quite thick side-walls. Do it in small stages so that you only remove JUST enough to give you clearance
