Technical  Fitting a reversing camera
MickeyP
Cambridge
I have just bought a Fiat Panda 1.2.pop 2013 and want to fit a reversing camera. I have already installed a car player & have fitted the lead into that but how do I get to the reversing light to fit the wiring that end. Any help would be much appreciated.
Year
2013
Mileage
55560
I fitted a cheap reversing sensor set to my 2013 Panda......Very easy to do....Pull up the boot trim on the nearside, there you can see the wiring .
Open the little panel behind the reverse light to identify the wire colour , the bulb lamp holder just twist to remove.then check which wire in the boot area is the positive wire and then tap off that wire...the negative pick up can be from any clean body attachment.I hope this is helpful.
