General Fitting a new battery
davidwilko
This should be an easy enough job right?
Any pointers/things to look out for?
Thanks in advance :)
Depends what Punto you've got. I had a time of it getting a battery for my mk2 Sporting. Had to get a special size one but straightforward to swap :)
One BIG tip, disconnect the negative terminal first, as the whole of the cars chassis/bodywork is connected to that negative terminal, if the positive terminal touches a piece of metal you will short circuit your battery! :) Upon reconnection, connect positive terminal, then negative terminal.
